Lol sound cool! I think it depends on the state, but yes in VA its taken by someone else. I have a different idea for my plate.Nice.
the suspension is different on those with that trim.
So I take it the name bumblebee is taken?
I ask as that’s what I plan on naming mine when I change the panels to yellow and get the tridion wrapped in black.
Lol I've been trying to figure it out too. The engine does have the Brabus badge on top. So far I'm calling a custom car with a luxury engine. Easiest way of doing it😂.Thanks for sharing pictures.
Interesting collection of “badging” BUT none typical of “built by Babus.”
Not sure exactly what you have???
A $32 BRABUS fuel rail cover will “badge” your engine, easy peasy...If the engine has the brabus badge then it’s a true unless someone swapped the valve cover.
Doubt someone would go through the trouble to swap it as it’s a bit of work to get to the valve cover.
Hate to ask but what is the difference of 450's? What are the numbers for?Post your VIN and someone will look up your data card to confirm exactly what your car came with originally.
Wahi, using Len’s build sheet (Datacard) I believe that you are right!Could it be the "City Flame" edition?
That's very true. I have one on my US spec Brabus. Installation time....less than thirty seconds.A $32 BRABUS fuel rail cover will “badge” your engine, easy peasy...
There's a small "BRABUS" badge on the lower right of the trunk on a real BRABUS as well.The give-a-way are the wheels. A "real" US spec Brabus had 15" front and 17" rear wheels. They were silver and the outer rim was smooth to the edge. This car has black wheels, all in 15" with a distinct raised edge on outer part of the rim. The only correct Brabus badges are the gas filler door, the triangles, and the grill badge. Where it has a Brabus badge on the hatch, it should say smart in chrome. The ones on the glove box, the shifter console, the center of the steering wheel, and fuel rail cover are all after market.
Certainly not bad mouthing the car, it is very pretty and well done, but it is not a Brabus, but a "City Flame".
