1 - 4 of 4 Posts
Just started to notice a low moaning noise that phases in and out going down the freeway. Takes about 5 seconds to fade in and out then a couple seconds between. Not real loud, to the point that I kind of forget about it sometimes but when I notice it, it annoys me. Low enough that I might have a hard time recording it. I have no clue what it could be.
Haven't taken it to the dealer yet because it's 2 hours away from me (and honestly just thinking about letting it go for the last year before I turn in the lease if it doesn't get worse).
Any ideas?
Should I cross rotate to eliminate this as a possibility?
A 2016 453 'should' have different width tires front to rear, and contis.
The contis are loud over 40mph; I notice the sound and loudness varies with temperature and road surface.
If the noise is tire noise, not much you can do on a leased car but change tires (all of them) but there aren't many brands for OEM stock tire sizes.
I haven't had a chance to try Vredesteins to compare against the contis as far as tire noise but the 17" set of yokohama summer tires I put on are way quieter than the 16" OEM conti set.
1 - 4 of 4 Posts
