I have a 2008 Fortwo passion with original radio and recently purchased an XM Onyx unit to get satellite radio. When plugging the power adapter neither the LED nor the radio turn on. I exchanged the unit and I am having the same problem with the new one. However, the power adapters for my cellphone and GPS work just fine.
Does anybody have this same issue? Does anybody have any suggestions about this? Is it that the smart does not provide enough power in the lighter adapter or could it be something else?
:welcome: to SCoA! Tell us more - are you using the 12v outlet below the center stack? Since other items work fine I can only assume it's a problem with the XM power plug - might not be seated fully or not quite the right size. Could also be a defective power cord. FWIW, I had an XM Roady2 in our 08 and 09 and it worked fine with the 12v outlet. Once you have three posts you can add some photos.
yea i had the same problem i simply removed the aux power plug to find out was going on and i found the fingers in the power socket were keeping the xm power cord from seating all the way so i spread the fingers wider and it was good to go
I have a sirius radio. I put in a 3 way adapter and mine works fine. I have been in some vehicles where the socket was not deep enough. If you are in Northern FL pm me and I will meet with you and see if we can get it figured out. Welcome aboard. Let the fun begin
Thanks for your replies. Looks like the socket is not deep enough for the adapter. To resolve it I got a 2-outlet splitter for about $7 and it had enough space to fit the XM's adapter plus now I have the option to charge my cell phone or GPS at the same time.
My 10 smart car does not have an auxiliary plug. What type Sirius xm radio do I need to get. How do I hook it up.
Related Threads
Smart Car of America Forum
797K posts
63.7K members
Since 2002
