1 - 4 of 4 Posts
My windshield washer pump was dead when I bought the car use. It’s an 08 model . First how hard are they to replace and where is it Located?
Administrator
1 Windshield washer water reservoir
M5/1 Windshield washer fluid pump
Location
The windshield washer fluid pump is located at the left in the direction of travel on the windshield washer fluid reservoir.
Task
Washer fluid supply to the spray nozzles. It is actuated directly by the right wiper switch (S4/4).
On model 451.3 the windshield washer fluid pump is designed as a duo pump. Depending on actuation, the pump's direction of rotation changes and therefore the conveying direction between the front and rear end.
You'll need to remove the reservoir to get to the pump. :)
Does one really need to remove the "front module" to do this job, starting with removing the front CBS?
(Starting to feel happy my smart is no longer with me...)
1 - 4 of 4 Posts
