Problem
2010 smart's highbeams will not turn off. The low beams work like they should. The only way to get the high beams off is to remove the bulb. Has anyone came across this problem or any idea of the fix. Thanks
Discussion Starter · #2 ·
Problem
The high beams will not turn off, the low beams work fine on and off like they are suppose to. The only way to get the high beams off is to remove the bulb from the light socket. Any suggestions
2008 451 coupe body/ interior with 2013 engine and trans.
I have not. But my guess would be to follow the trail of electricity until you find the culprit. Any chance its the high beam switch not functioning?
