Maybe you haven't noticed (neither did I until someone pointed it out) that smart has made a running change to the inside cover of the glass hatch - for 2010 models. They've added a drain hole at the bottom of the plastic cover, in the area where the lower end of the support struts are attached. Now, at least if your hatch does get some water in it the water has a place to drain out. Easy DIY for 2008 and 09 models - take a drill (1/8 inch bit or so) and put the holes in yourself. When you're done it should look like this:
