1 - 17 of 17 Posts
Does anyone have instructions on how to disable the noise generator on the latest Smart ED?
Please don’t think me rude but only post if you have an idea, lead or know how to. Please don’t post off-topic opinions on the process, I think we’ve discussed that thoroughly and I do want to create a helpful how-to, thanks :)
MPT
there is no way of taken it out will cause the car to go into a fail safe mode.
there is another way.
you drill 2 small holes in the box, one on each side of the speaker and fill both side of the box with spray foam
you can get It at any hardware store.
Gary,
Thanks for that, it's good to know that disconnecting triggers an error. Where is the unit? I have my can at the ready. I also wonder if it's possible to disable it by dismantling it and inhibiting the speaker through a 'fault'.
MPT
It is a federal law not to disconnect it.
That's why the car will not move if you unplug it.
Virtually any federal MVSS or EPA emissions standard that can be altered (or simply fail) without immobilizing the car! The feds do not mandate any kind of car immobilization for the disconnection or breakage of any gadget needed to meet a standard. So don't blame the feds for this.
The number of ways MB micromanages us with busybody-ware programming is enraging. Especially becasue, in a couple more years, there will be no dealers or shops to fix a Smart ED/EQ immobilized from a software fault detection that needs to be reset - your mechanically-perfect car will be a brick.
One of the whole benefits of EV's is quieting the urban environment, the noisemaker works against this.
Most pedestrian-vehicle accidents are the vehicle drivers fault - typically making right or left turns into pedestrians already on the crosswalk and having the right of way. The noisemaker does nothing to prevent these.
At the low speeds the noisemaker operates, and EV does not present a hazard to even jaywalking pedestrians. The car has a horn, and brakes.
· King of Smart Gadgetry
I'm pretty sure disconnecting the noisemaker and shorting the wires together would cause an error code just same as disconnecting it because can bus indirectly reads resistance. That's the reason they make error canceling can bus resistors when you replace your headlight bulbs with LED's or HIDS with a ballast that changes the expected resistance value in a circuit. When I put HID's in my Fortwo it did cause an error code to set, but it wasn't a code that would light the CEL. I merely found it when I did a scan for another issue. It told me the headlamp resistance was out of spec on my left headlight and my right. So you would probably have to ohm out the speaker and include a resistor in the circuit of you did disconnect the wires. DCO
The noise maker is almost impossible to hear inside the vehicle even with the windows open unless I am in a covered parking garage. I wouldnÂ’t disable it. ItÂ’s most useful in parking garages where there are no pedestrian walkways and walkers lollygag when they donÂ’t think a car is coming.
ItÂ’s also useful to warn jaywalker and jay bicyclists.
1 - 17 of 17 Posts
