Status
Not open for further replies.
1 - 2 of 2 Posts
Ex Admin/mod.
To help you post your picture, here is a quick how-to:
1. click on <GALLERY>
2. click on <Upload>
3. click on [Choose File]
4. select the picture you want to post, either on your desktop's or in a file's list
5. opt for [Choose]
6. Enter a title in the <Image Title> box
7. Choose a category in the <Category> box, i.e. the first one: <Member Galleries>
8. you can add keyword(s)
9. click [submit] at the bottom
10. Once your picture is loaded, click, select "all" and copy the whole link that is in the box <Direct Link Code>
11. In the post you want to include the picture, click on the
and REPLACE what's in there with the link you copied from the <Direct Link Code> above (be sure that there is only one set of "http://") and <OK>.
That should do it!
Note: Users must have three posts before they can add pictures and/or links.
Size & type are somewhat limited (you can see the details in "View Allowed Extensions" after you completed step 2 above), but substantially higher for Club Members.
Using a public photo server: simply insert the <IMG link> where you want your picture to be posted, or paste the pic's <direct link> as stated in step 11.
It has to be a public server, a link to a secured account or your own computer won't work.
Ex Admin/mod.
Discussion Starter #2 (Edited)
Posting several images at once
When we upload several images at once they all come up with the first picture's thumbnail and we're given a last chance to diversify their titles. Once they're "processed" they will be different if titles are different. Otherwise that's what we get... different picture under the same thumbnail. :rolleyes:
Example:
In this instance each picture has a different name (a different number in the upper left corner) but show the same thumbnail. When I change the middle picture's TITLE (I added a "2" in the highlighted box) BEFORE clicking "Process", the thumbnails will be different. But if all pictures have the same TITLE they will all show the same thumbnail.
At least that's how I understand it to work after several tries. :wink:
1 - 2 of 2 Posts
Status
