The passenger side running lights are out so I need to know how to remove them.
Are you talking about the passenger door?On the 451, There is a metal tab that holds the lens assembly in place. You can see and reach it with a long screwdriver from the door opening. Open the door, reach in with the long screwdriver, gently press in the tab and push the lens outward. It should pop out with hour much effort.
Are you talking about the pass or driver door?On the 451, There is a metal tab that holds the lens assembly in place. You can see and reach it with a long screwdriver from the door opening. Open the door, reach in with the long screwdriver, gently press in the tab and push the lens outward. It should pop out with hour much effort.
Is it the two grey tabs or the three black tabs?I’m talking about the lights on the sides of the car mounted just in front of the doors. They flash I synchronization with the directional signals.
And if all four aren't working do I have to replace the whole unit or are they all separate bulbs?I’m talking about the lights on the sides of the car mounted just in front of the doors. They flash I synchronization with the directional signals.
If all 4, then probably an electrical, not a bulb issue. Loose wire?And if all four aren't working do I have to replace the whole unit or are they all separate bulbs?
My side markers only have 1 bulb each. Can you post a photo of the light you are working on, please?
