1 - 3 of 3 Posts
My drivers side window switch is broken and loose and needs to be replaced. Does anybody know if I need to remove the entire door panel to remove the window switch or can I just pry the switch out with a flathead screwdriver or does anything else need to be removed to access the switch. Thank you.
You do not need to remove the door panel. I think you need a plastic trim tool to pry loose the top of the silver triangular trim covering the switch panel and door pull. Then you can use a small screwdriver to release the lock tab at the top of the switch panel and pull it out to disconnect the harness connectors.
Thank you. Will give this a shot when my switch comes in in a couple days.
1 - 3 of 3 Posts
