After scanning with my Autel MK808:
P056200 Low voltage
B1F6716 No info
C212B11 Brak Vac pump short to ground
C212B16 Brak Vac not ok
C212B92 No info
P0A8D00 No info
P160300 Steinbauer module (I know this over current)
P160600 Steinbauer module (I know called for over current)
P160800 No info
P172C53 No info
The car charges fine, drives normal, vac brakes work fine as always, the 12v gets charged while car is on and when charge cord is in. All gauges work and indicate as normal.
I do not know what is holding this error open, I routinely scan for codes, I have had this Steinbauer module for 6 months and never set any codes, last month I had no codes. Then the car sat 2 days with the charge cord plugged in, I went to it one morning and turned the key and all dash lights dimly lit and the contactor click buzzed so I replaced the battery and all these codes showed up.
