1 - 10 of 10 Posts
He's not mine
I think this is a first. Wanna know what y'all think about it.
Today upon starting the car at lunch time, I noticed the driver's side heated seat was powered up on low. It's always been Off on startup, regardless of what I had it on when I shut the car off.
After work, started the car and the same was true ... driver's side on low.
I played with it and found that instead of a three way toggle (Off, Low, High), I now have two ... Low, High, High.
Bad switch? Thoughts?
This is going to be undesirable soon with Summer heat on the way. I haven't checked yet to see if they're on their own fuse. Pulling the fuse would then be at least a temporary solution.
He's not mine
No codes. But, now that you mention it ... yes, we've had substantial rains. And, last night I forgot to close the passenger side window completely (doh). It was down perhaps 2 inches and the passenger side got some water. Not flooded, but dampened.
Hmmm.
Odd that the problem is on the driver's side if that's the cause though.
He's not mine
Discussion Starter #5 (Edited)
Was wondering about general flood damage after watching the news tonight; didn't see that as causing the seat problem. :)
That would be a different thread. As for your question, nothing major. It rains, streets flood. We're used to it.
EDIT at 0430: Catching network news ... I see why the concern. Funny how media makes things seem so much worse than it is on the scene. I am 100 miles from Pensacola. But, even when the national coverage is on the local area, they do tend to make things seem worse than the average Joe would tag them to be.
The switches are impulse switches( they send a signal to the sam to turn them on,no current runs though them like a light switch.) I would try the disconnect the battery trick first.
He's not mine
Discussion Starter #7
I'll try that this weekend Digger. Thanks. Hope that will solve it.
I'll follow up.
?..no current runs though them like a light switch.
Not quite correct for home wiring. May or may not be correct for auto wiring. Light switches for home wiring break the positive feed. Touch that and ground yourself and you will find there is current running through the switch. You might not live to tell about it, though! =:-(
The seat heater switch is just an input to the heated seat control module, which in turn supplies current to the seat heating elements. So the question is whether the fault lies with the switch or the module. You can unplug the switch group and see if anything changes, or you can unplug the heated seat control module. The heated seat control module looks like an oversized relay that is next to the steering column under the dash above the accelerator pedal. If no result, you can disconnect the plug for the heater under the driver's seat. It should be a two pin plug with RED/BLU and BRN wires.
He's not mine
Discussion Starter #10
<scratching head>
Well, today the problem seems to have rectified itself. Go figure.
Good information provided and I appreciate it. If it should raise its head again I'll know what to try. Thanks!
1 - 10 of 10 Posts
