1 - 9 of 9 Posts
I came home from work today, driving my 2015 smart electric, which I've been doing for the past four days, thinking that I wanted to haul an old TV to the Goodwill place. For that, I decided my 2014 E350 Coupe would be the better choice, so I parked the smart on the street, opened the garage, opened the Merc, pressed the ignition button and... nothing.
A quick survey of the vehicle suggested the battery was stone cold dead. A call in to Mercedes Roadside Assistance found a technician just four minutes away, and in minutes he arrived. Yup, the battery needed a jump. All the systems checked out, so I got the jump and the tech told me I should give it a good 25-30 minutes of driving to charge up the battery. So I did. Filled it with gas, even.
In the 25+ years I've owned Mercedes cars, I've never needed a jump start! My E Class has only 19,000 miles on it, stays garaged (except when I'm traveling and leave it at the airport -- as I did Tuesday through Thursday last week) I can only surmise that it's been feeling neglected now that I've added my smart to my stable. Poor thing.
I'll drive it tomorrow. :eek:
I have this
https://www.amazon.com/Schumacher-S...03942&sr=8-1&keywords=schumacher+ship+n+shore
connected to the jump points under hood of a '12 Mercedes in the garage, set to the appropriate battery type setting, (AGM I believe is correct for yours). Unplug, remove the clamps, close the red + cover, car starts right up 100% of the time....
Recommended by someone on a forum, I can't remember which, I am on somewhere.....
I have this
There is so many electronic systems drawing on a battery during long term sits , I would suggest the tender too , plus it will keep your battery healthy too .
Sounds like a battery tender is in your future.
Funny you should mention that. I just came across one today online. Said to myself, "Hmmmm."
My, how technology has come since the days of jumper cables (of which I have a pair).
10Year+ Supporting Member
I have had good service from the "Del Tran" brand of tender. I have been using them for about 10 years on everything from cars to lawn mowers.
Electrical problems in a modern Mercedes? That's something never seen before! ;)
I had a 2000 CLK430 which was produced during those awful Mercedes-Chrysler years. The electrical system on it was grafted onto it from Chrysler's harness, and I had lots of issues with unexplained warning lights, check engine lights, misfires, etc. Once I moved to the newer E-class vehicles (I had a 2012 E350 and now my 2014), not a single electrical problem.
Until Tuesday.
You should have it checked for parasitic current drains, and I would be pushing them hard on that point because the car presumably is still under warranty. My 2008 M-B has the original battery and has never needed a jump even after 2 months of inaction.
Our 2002 M-B never had that problem either, though it did have others (as does the 2008).
1 - 9 of 9 Posts
