21 - 22 of 22 Posts
Discussion Starter · #21 ·
Ditto above.....Test your battery, see if your getting 12.4 volts from it. Have a load test done on the vehicle. Any auto parts store will perform one free of charge. That will make sure you alternator is charging.
You mentioned, you have aftermarket LED lighting. Go back to incandescent lighting. LED’s can play Havoc on your electrical system.
Well, it’s been more than a week now, but I replaced the battery considering how much everyone believes in it. Haha. Based on the replies here and other threads I decided to replace no matter what. Put the new one in and THEN tested the old battery. I kind of hate to say it, but the OEM battery still tested good. Haha!
However, after all of this neither turn signal worked properly. I swapped around the Relays and they started working. Doesn’t make any sense.
I have not noticed if the parking lights are coming on randomly while driving as before. The headlights do click on and off just a few seconds after starting the car. Every time. They cycle a couple times before staying off. I do not have the Auto lights Option on the switch.
21 - 22 of 22 Posts
