Are the temperature control systems on the 12V cabin battery, or on the traction battery?
If they are on 12V, then a possible range-adding hack, especially during winter, might be to move those range-robbing systems to a hacked lithium-based 12V system, separately charged. The system could be sized based on a few amp measurements, large enough to get you to the end of the potential range on the added batteries.
Anybody know what voltage those systems are using?
The heater core and the air conditioning compressor run on the high-voltage traction battery power. Running a thousands-of watts heater on 12 volts would be highly impractical as it would have to draw hundreds of amps at that voltage - the AC compressor similarly! The heater/AC blower runs on 12 (actually at least 13.2 to be nit-picky) volts, and, like IC engine cars, the heated seats (which use much less energy than an air-heater) are 12 volt. That is why heated seats are so nice an option for efficient winter driving in a EV.
You can always tell what has high voltage in any EV becasue the wires are clad in bright orange.
For winter driving, when I select 'automatic' it turns on the AC, is that normal or should I deselect that? It seems to heat things up pretty quickly but it doesn't seem intuitive to put AC on when it's -5 outside...
Cheers.
The use of AC to dry the air isn't needed. The heating of outside air knocks the humidity way down a defogs/defrosts the windshield fine. I never even has a car with AC for decades and the heater worked fine on the worst days. Most IC engine cars will cycle the AC on an off when using the heat, but I disable it in winter to help the fuel economy a bit.
My Smart does not have any "automatic" setting.
