Hi Everyone!
I haved owned this for two years without a problem, But Recently it has started blowing the #10 fuse, at first it was when you would shut the car off it just wouldn't restart, change the fuse let it relearn the clutch (because when it blows it locks the gear shift and the P disappears from the cluster) and go on. Then it started blowing every two weeks.
Now after driving home one night the car blew the fuse and kind of stalled out ever since then the Fuse has had a dead short. :shrug:
Can anyone Tell me what that fuse powers, The owners Manual Just says "Engine
" I was under the impression from a page i found that breaks down each fuse.... that it Powered the Secondary air valve, The Injectors and the Upstream o2, checking all those with a test light show power on them with the fuse out
(also Unplugged the clutch actuator and cleaned it, replaced the fuse and it blew)
This thing is driving Me Crazy!
