The claim is that some cars monitor the lights and indicate on the dash if a light bulb is out. It does this by monitoring the current pulled by the lights and it knows when a light is out due to the light pulling no current. Since LED lights pull much less than then non LED bulbs, the sensor would see this as a light out. The Canbus error free lights have resistor in them that makes the sensor not report the light as out. I don't think Smart's have that sensor.
I’ll go for the direct answer :p
“Festoon” is the shape of the bulb. It’s basically a rectangular bulb/LED with a connector on each end.
“CANBUS Error Free” means that it has a little resistor in it so that it doesn’t trip your smart’s rapid turn signal flash.
So, if you’re replacing the license plate lights, you’re going to want a festoon CANBUS LED.
I recommend getting CANBUS in every LED. In my experience, even if the smart detects too little resistance in the license plate lights it’ll trigger the rapid flash.
Reactions: TRobinson6
