Hey, I recently bought a 2016 Smart and am starting to make customizations to it. I switched out the bulbs from halogen to LED, but now one doesnt work. What am I doing wrong? Thanks!
Hey, so yes the heat sink is outside! It’s weird, because the high beams work no problem, but the low, one doesn’t work. I have this same exact problem on my Mercedes as well.You can try swap bulbs left to right to see if it is the bulb itself or simply a bad connection.
Is your new LED bulbs totally enclosed inside the housing or with heat-sink outside?
If LED is totally enclosed inside the housing, the heat generated by the LED itself may fried the embedded electronic components due to lack of cooling.
Check your fuses. Each headlight has it's own fuse 22 is drivers headlight low beam and fuse 23 is passenger side low beam.Hey, I recently bought a 2016 Smart and am starting to make customizations to it. I switched out the bulbs from halogen to LED, but now one doesnt work. What am I doing wrong? Thanks!
