Left turn signal not working
Left brake light not working
Running light works
I have done the following,
any ideas on what direction to take next?
Running light works
- checked the left bulb and didnt appear to be burned out
- swapped left and right bulbs to see if the issue follows when I put the original left bulb on the right side (it didnt)
- checked #6 fuse, also didnt appear to be burned out
- swapped #6 fuse with #7 and the issue did not follow
- swapped relay A (left turn signal/stop lamp) with relay C (same part number) and still no fix
- visually checked the ground next to the fuse box, nothing loose or any physical evidence of an issue
- visually checked the wires going into the panel where the bulbs go, they looked normal but I only looked at what is physically in front of me. I did not rip and tear to follow the routing of the harness.
