I'm so confused over my prospective lift and tire change.
I've called daystar, smart madness and tire rack and haven't found an answer. I've searched this forum and have more of a clue. I figure a direct question would be the way to go.
I'm wanting more ground clearance for the flooded streets typical in my neighborhood and wider tires for the hunting camp.
I'm looking at the 2" lift kit from daystar. My biggest problem is choosing tires. I plan on running stock rear steels on all four corners. I'd like to put the biggest tires the car can hold. Minor trimming wouldn't bother me either. I've put a sawzall on many of my 4x4's.
Daystar's website states that you can run up to 175/70-15 front and 185/70-15 rear. It doesn't look like these tire sizes exist. I called tire rack and they suggested that I do more homework. Smart madness suggested that I do more homework as well because of rubbing issues and possible computer-confusion issues.
I would also like an all terrain dot approved tire if possible.
So again my question…
With a 2" lift, what are the biggest and widest tires I can run on rear stock steels at all four corners?
Thanks in advance!
Thanks in advance!
