Battery Charger
You would have to leave the key in the #1 position to use the power point as a plug-in for the charger. Acquire a Battery Tender & it has a wire lead that you can permanently connect to the battery. Run the wire under the battery cover and carpet and have it exit under the dash in front of the counsole. You can then plug in your Battery Tender Charger, roll one of the windows down slightly, place the power cord outside the vehicle and connect to an A/C power source. You can then charge your battery without having to lift the carpet and remove the troublesome styrofoam battery cover. You can also lock the doors. Make sure you place something non-combustible under the battery charger in order to avoid the possiblility of a fire. A board or insulated metal coaster will work as the charger can get warm, especially if the battery is low.
