When I turn on the key, everything comes on as usual. Then the gauges start clicking on and off rapidly. It also does this while running. It's like someone is turning the ignition switch on and off. The lights, ac, gauges go off like you turned off the ignition. Today I had the door open when it is doing this, and engine is also cutting out as well. Like I said, it's like someone is rapidly turning the ignition on and off. Any suggestions?
Thank you!
Thank you!
