1 - 20 of 22 Posts
· Ex Admin/mod.
Since I won't clear the display on my car (I count on it to remind me when the time comes), I won't try it myself. But as you're looking for it, can I suggest to press and hold the left button for at least 10 seconds while it's showing the maintenance interval, and see if it clears?
As for your second question: some owners have past 10,000 already. Obviously none read your post... :confused:
i may be wrong, but the manual recommendation i believe was just to cycle the display from maint interval through the other displays (trip odo, etc)...
i "thought" that the interval had to be reset via the computer. don't know if perhaps the scangauge can clear it?
reset Maintenance / 2 methods
Method 1
Switch on ignition to position 1
Select maintenance indicator within 4 sec. by double tapping the instrument cluster button
Switch off the ignition to position 0 (off) within 10 sec.
Push and hold in the instrument cluster button and switch ignition on
Hold the instrument cluster button for another 10 sec
In that time, the spanner symbol on the LCD will flash and eventually reset
Method 2
Switch on the ignition to position 1
Select maintenance indicator within 4 sec by double tapping the instrument cluster button, keep it held down on the second press.
Switch ingnition on
Keep the instrument cluster button held down for another 10 sec.
In that time, the spanner symbol on the LCD will flash and eventually reset.
PS Got This from SteveM1tx, it does work!!! Hope it helps
p1nball :cool:
Method 1
Method 2
Switch ingnition on
p1nball :cool:
pInball,
I did both methods, 1 and 2, hoping to permanently clear the maintenance indicator, numerous times but to no avail. The maintenance indicator - flashing spanner- will show up with a neg number (now it's -400, was -200) before it disappears when I put smart into gear.
( I also read the manual..). Unsure if I'm too fast on the tapping or the key postion changes...
I am in the same boat with my Bumblebee. Had the service done and they FORGOT to reset the maintenance counter so now I see the wrench and - miles at start up. Dealer says they can't reset it without hooking to the computer. Not that it isn't possible to do, they just don't know how. I have tried all methods mentioned on this forum, as well as speak with Smart in Germany....nothing has worked. The cars in Germany have a whole menu that comes up with that left button...we only have maintenance and trip odometer reset.
Any suggestions appreciated. It is 100 miles to the dealer:(
the directions p1nball gave do work... BUT maybe not the first or tenth time it odes work just have to hit the sequence right. Took me 20-mins of fiddling between the methods before I hit the sequence just right and no I cannot remember what that was that finally got it done...
Maintenance Reset:
- Apply handbrake
- turn key on, do not start, shift to reverse
- turn key off & wait for screen to go blank
- turn key on & quickly tap the left button twice (double wrench appears)
- turn key off
- press & hold left button then immediately turn key on
- continue holding button for 15 seconds
- 10000 appears and reset is complete
If this does not work try duct tape.
I'm pretty sure this only works when the time (digital display) shows sequential numbers, like 01:23 or 12:34...
Alternatively, you can sacrifice a chicken and bring the car to a smart center...
Just sayin'...
1 - 20 of 22 Posts
