I 've bee looking for info regarding intake manifold pressure sensor location for the last three days. It is not what you guys talk on the forum...where it is on this model. Please help
Thanks so much that will help a lot....A big thanks for the picture
I changed mine last year by supportilng the motor and tranny from below on a trolley jack, removing the top motor mount bolts on both sides,
remove one bolt from the dog bone lower mount then lowering the motor as far as possible (until things started getting well stretched) then rolled the motor (top) to the rear) then crawling over the top of the motor and reachig down to loosen the mounting screw and pull the plug off. Like I said, it';s been awhile, and having tuorned 84 last week, my memory isn't what it used to be. Don't remember, but you may have to unplug the wiring harness on the motor, but I don't think so. It's not real easy, but it CAN be done, and from the top.
Does anybody know how to change it...It seem not accessible.
Do you know the number of part as well...the pictures it s so blury
If the engine is still on the car, then there is no way of accessing it. You need to take the engine out, or make a hole on the metal part through the inside of the car. (Like i did)Does anybody know how to change it...It seem not accessible.
Hi can send a picture of where you made the hole please. ThanksIf the engine is still on the car, then there is no way of accessing it. You need to take the engine out, or make a hole on the metal part through the inside of the car. (Like i did)
Here is the exact location of it. View attachment 64133
