21 - 22 of 22 Posts
Smartmadness.com
Discussion Starter #21
Heres whats in transit to me:
EBC Performance Brake Pads by Smartmadness
Designed for premium street driving. Offering better brake effect up to 600°C (1100°F). EBC Greenstuff brake pads have a high initial brake effect and give drivers confidence from first application of the brake pedal.
There is no such thing as a NO DUST pad. The very nature of how a brake works requires that some dust be generated to avoid rotor vibration (shimmying). The EBC pad creates less dust and dust is more easily washed off than most. All pads create more dust as they are bedding in especially if rotors are worn. Nominal friction coefficient 0.55. EBC
Also on its way to complement the pads
EBC Cross Drilled/Slotted Rotors by Smartmadness
This set is manufactured using premium disc blanks. The unique wide aperture slots in the EBC sport rotor helps in drawing cool air under the pad during heavy braking. This reduces brake temperatures and also helps with removing dirt, dust, debris and gas which are created by heavy braking.
Pics are in the Modification section of the forum
Smartmadness.com
Discussion Starter #22
EBC Cross Drilled/Slotted Rotors and EBC Pads (Installed)
My EBC Cross Drilled/Slotted Rotors and EBC Green Stuff Performance Brake Pads have arrived and just been installed by Mercedes Benz of Buckhead/Smart Center (ATL, GA)
Product Vendor: Smart Madness (So-Cal, California)
THANKS SMARTMADNESS!!!!!!!!!!
TO VIEW THE PICS THEY ARE POSTED UNDER THE MODIFICATION THREAD as 2micro4u Stopping Power upgrade!!!
21 - 22 of 22 Posts
