Hi, Does anyone know if a 6.5" wheel with a 195/50R15 tire will fit on the front of a 2008 Smart Fortwo Passion without any modifications? Wheel has a 30mm offset.Looking to upgrade wheel and tire setup.This is the description of the wheels I am looking at (6.5Jx15ET30). Any input would be appreciated. Thanks Munster
aka 'smart-1'
Click on FORUMS near the top, then scroll down to the W&T section.
-MODS- Need to move this to the proper section .. :rolleyes:
10Year+ Supporting Member
A Hankook 215/35-17 tire on a 7.5x17 Brabus wheel will fit on the front with no modification. Other brands of tires in the same size may need a wheel spacer of 5mm to 10mm. Good luck in your wheel and tire search.
You should be fine with the tire and wheel size you are planning on.
