1 - 20 of 26 Posts
Hi everyone,
So to make a very long story short, or you can read here... my battery, which I thought the problem was fixed, is not the battery at all. After several weeks at the Mercedes dealership, they have determined that the 'module' that connects/disconnects my HV battery and my 12v battery is 'blown'. Thus draining my 12v battery very quickly and killed my new battery within a week or two.
I can't seem to get a straight answer on what the part is, but they are quoting me $4200 ($3500 for a refurbished) for the part and $2000 for labor.
They suggested that I could connect to a trickle charger every time I turn off my car. Given the location of the battery and the fact that I live in a townhouse without access to a power outlet, this doesn't seem to be a great solution.
Has anyone else had this issue? What is the part? Is there a reasonable workaround? Is a workaround even safe?
One of the mechanics said that this part disconnects in the event of an accident to keep the car from blowing up. They also mentioned that the damage could have happened from a minor hit to the car.
I would love any suggestions on fixes and to hear if you had this experience.
Thank you!
UPDATE: I finally was able to get the part that needs to be replaced. The M-B dealership said it was the power-electronics module. This is the $4k part.
Well that’s some useless drivel from your M-B dealer! First and foremost, I don’t believe that the NHTSB has any report of a smart fortwo having “blown up.”
Have you been in a fender bender (minor hit)? It sounds like they are describing the “pyro fuse” which can blow when the accident sensors detect trouble and “disable” ED.
$4,200 repair makes no sense if the service is just to replace the pyro fuse???
No, I haven't been in a fender bender but I do park in an alley... it's not impossible that someone slightly tapped the car. It doesn't have any damage.
I don't know what part it is... they don't tell me. I have asked several times for the quote to be emailed to me and the exact name of the part but I can't seem to get a straight answer. They call it a 'module'. The module/part that connects the HV and 12v batteries and tells the 12v to disconnect when the car is off. The $4200 is the cost of the part only! This 'module'.
Only thing I can think of connecting the two is the link for the DC-DC converter, or whatever terminology Daimler/Smart uses. Those are supposedly expensive.
EDIT-. What model year is this? Someone here had a different issue that caused his 12 V to boil basically. Smart/Mercedes took care of it under warranty albeit a while ago...
The battery test unit uses the work "CONTACTOR." With the car not turned on, the 12v battery is not connected to the HV battery and the test unit says the the "CONTACTOR" is OFF. When the key is turned ON, then the test unit shows that the "CONTACTOR" is ON, meaning that it is connected to the 12v battery. Is that where the problem is? Your guess is as good as mine.
What they are telling you does not make any sense. As an engineer, l hate in when someone thinks a concept is only understandable to a non-specialist if it is "dumbed down" until it is gibberish.
There is a DC-DC converter that converts the 370 volts in the HV battery to about 14 volts for charging the 12V battery and powering the lights, windows, wipers etc - i.e. it serves the same function as the alternator/generator in an IC engine car. Unfortunately this converter is integral with the Power Electronics Control Unit (N129/1) which is the power inverter (DC to 3 phase AC) and controller (the "throttle") for the motor. N129/1 is the biggest aluminum box you will see if you lift the carpet and open the engine compartment behind the seats. Like every other component on the Smart ED is it outrageously overpriced. I have no idea why it would cost $2000 labor to replace it because it is jsut a simple part replacement and some software resetting.
I can only assume that MB deliberately overprices parts and service on Smart ED' becasue MB management regards the smart as an "embarrassment" to their snobbish upscale MB Brand and want to speed the flow of the remaining ED's and EQ's into the junkyards.
Of course, you might be able to find a junkyard N129/1, install it yourself, then have the dealer do any software reconfiguring that is needed.
In your other thread Len pointed out a potential software update. I’m guessing it hasn’t been done either due to the car not qualifying or just not done yet. You should have received a receipt with that detail in there if it had been updated. At this point try to figure out if it’s an open campaign and have it done (at rightful no cost to you)…
If your car spent time at a dealership for any reason, they should have updated your software automatically if it needed it, but they should have also told you they did. With your VIN they should be able to tell you if your car has had that update or not.
Len,
Idea...
If the defective ECU is discharging the 12V battery, you can wire a switch to the negative terminal of the battery and flip the switch to disconnect the 12V battery when the car is not in use. Or a more sophisticated method would be to wire the keyswitch (if it is a switch and not a Hall device) to a relay (solid-state relay would be ideal) on the 12V negative lead of the battery. Your clock/and radio setting would be lost - but at least the car is still usable.
To add to the pool of knowledge on Smart ED failures. Mine suffered intermittent draining of the 12v battery from when I first bought it as a warranted used car. Initially it only happened three times in a year then progessively got worse. I reported the problem to the dealer and their response was always to replace the 12v battery and not investigate any further.
Some time later I returned to the dealer with the same fault and, while the car was in their posession, the failure of the 12v supply eventually killed the HV battery. This was replaced under the BAP, but of course it did nothing for the intermittent drain on the 12v battery which continued. By now I was keeping the 12v on a trickle charger and carried a jump pack when I went anywhere.
Having measured the drain, when it happened, at around 6 amps I asked around a few other owners in the UK. One had experienced the same issue, eventually requiring the Power Control Module (PCM - that unit above the motor) to be replaced. This does two main jobs - DC/DC conversion from the HV battery to supply the 12v electrics and keep the 12v battery topped up, and DC/AC conversion to run the drive motor.
Shortly after, my ED failed at the roadside and was recovered to the dealer who by now was aware that there was more than a faulty 12v battery going on. They correctly diagnosed failure of the PCM, requiring an around £4,500 replacement. Facing writing the car off, I pleaded with them to try and secure a contribution from MB, given that they had failed multiple times before to correctly identify the fault. In the end they won out and got me a 70% goodwill contribution from MB, helped no doubt by a FSH from the same dealer.
SO the PCM failed under warranty, and even with a full service history you still had to pay £1,350??
Sorry. I didn't make myself very clear. The car was 7 years old when the PCM failed. I basiclally had three options at that point:
1) Scrap the car as, even though it had a brand new HV battery, it was essentially useless.
2) Work with the good people at EQPassion (https://www.eqpassion.de) who offered to take my faulty unit and send me a recoded working part.
3) Talk nicely with the dealer who came through for me in the end.
Hmmm,
There are screws which link the 12V main wire to the front and electrical distribution system and also main fuse close to the 12V battery. Did you ever take off this connection? And recheck the current drain?
Also there is a connection tompower the while ECU or better drive inverter ( build by continental), in this case also there could be a draining load reason.
In my view often the failure could also disappear by exchange of the Unit and just fixing some trouble in the wiring in parallel. So they unknown solve the real hidden issue by the expensive solution. But main goal reached. The car is running again.
And even option 2 would not work as it is not only the VIN which need to be changed but also on part of the security protection of the car is stored in the drive inverter. So it musst be teached in car by the offical shop.
So you did the right decision to get your car running again.
Idea...
In the "for what it's worth" department, my car came from new, with a high amp key type switch, like Harbor Freight sells, inline with a separate brown lead to the ground bolt. It sits unused, and remains unconnected to the battery. The normal clamp with the current sensor resides on the 12v battery. Not sure why, or who put the switch in.
PCM - Power Control Module in MB-speak. Generally known as the 'Inverter'.
These are available from San Diego etc, so simple replacement with a used one should always be considered. So 'G' had a 4th option which should have worked aces and cost relative peanuts. Should we all obtain a spare used Inverter 'just in case'? I will avoid any suggestion here; I'm still trying to open mine up what with those penta (as opposed to hex) housing plugs. :(
I'd imagine there are plenty of electronic spares around now. I've got 3 good BMS' and a full assortment of other car electronics for sale. Just looking for new battery cells....
message deleted
I have a blue 2014 451 smart ED and recently bought and successfully repair some HV battery problems.
Lessons learned :
1. make sure your 12v battery is change every 3-5 years inexpensive at autozone and buy a battery charger if you plan to go on vacation $30 battery tender plus or similar.
2.Do not jump start using the negative pole of the battery because you will damage the battery temperature sensor, ground the negative bolt grounding to the chasis .
3 . Is a common problem for this model to fail the outside temperature sensor is a $15 part easy to replace if you see inaccurate temperature reading in you dash board !!!
This will cause a chain reaction and disable the onboard charger and dc to dc charger
4. I use an Autel Maxi AP 200 Bluetooth with iphone app for code troubleshooting and status of 12 battery , HV battery, onboard charger etc highly recommend it! About $60
1 - 20 of 26 Posts
