Hi guys,
I'm looking for this multi purpose electronic gage, it would show AFR and boost plus other useful info.
The only thing that comes to mind is called the xgage but not sure if that's what it is.
I remember it being I'm the clock pod and it having a little rectangular box in the center with different modes.
Can anyone help me find this gage?
Thank you
Luca
Sent from AutoGuide.com App
Keep in mind if you're using a ScanGauge with a piggyback computer -- the ScanGauge will only show you the "clamped" or altered signals from the piggyback -- not the real ones... I think you want to see the real ones... AEM makes a decent wideband A/F gauge, as does Autometer. Some have installed these gauges in place of the clock in the Smart dash pods. The SplitSec piggyback has an RS-232 output port -- you can see "real time" values for boost, A/F, timing, etc., etc., displayed as a gauge or chart on a laptop.
I squeezed a 60mm swoosh stepper motor boost gauge in the clock pod. It is very tight, there is very little depth to the pod. Good luck on finding anything that will fit.
