First of all, the adjustment is with the slotted holes for the mounting bolts. The correct way to adjust it is described in the PDF link below. However few of us have the measuring tool noted, so what has been found to work well is to use the hash lines provided on the mounting surface. Have the actuator in place with the bolts loose, slide the actuator toward the clutch until you feel it contact the clutch arm, note where any of the hash marks are in relation to the slotted hole, push the actuator in 3 more lines worth and tighten the bolts. Note how that position compares to the line/mark you made before removing it. It should be fairly close, if it is right on then the original adjustment was still good.
It looks like you need to lube the inside with white lithium grease spray, not too much. Search this site for lube clutch actuator, a few member have detailed instructions and pictures. Post back if you have problems.
