I've got a 2008 451 Pure. So, I recently replaced my clutch actuator after the one that was on the car when I bought it failed (worm gear broke). I got the new part online and it looked slightly different, nicer milled surface instead of a sort of rough cast on the casing compared to my original actuator. This may or may not be related to the problem.
Since I installed it, I've had trouble with the car basically dumping the clutch when starting to move, whether into 1st or Reverse. It sometimes makes a bang sound and moves far faster than it should without me pressing the gas pedal. Often when I start moving it slams the clutch, retracts it for a moment, and then clutches in again. It also lurches downshifting from 2nd to 1st. I recall it occasionally doing this before, though it seems to be worse now.
I've tried adjusting the position of the clutch actuator and it improved the situation for a couple days, until once it failed to clutch in and I rolled back when starting on a hill. After that it seems like it's overcompensating and slamming the clutch even harder.
Has anyone ever experienced this problem before? Is it probably the fault of the actuator itself, or maybe a sensor or the shifter motors? Nothing I can do in my driving style EG holding the brake to start, getting on the gas very gently, seems to help. It also shifts totally fine when it's moving, the problem is pretty much exclusive to starting to move from a standstill or downshifting into 1st. Is there a way to force a fresh transmission teach-in? I know you can teach the transmission when the 3 bars come up, but that only seems to happen when the car decides the transmission is bad enough, which it hasn't yet.
