I saw a new device on Facebook that clamps on the rear window latch hook (on the window) and extends it a few inches. I got one and am trying it out. It arrived today and I took a short drive to see how it worked.
with both windows open, airflow goes in the sides and out the back. doesn't blow past your head and out the other side so cuts down on wind noise.
You hear the motor and exhaust noise more, and with a cracked flex pipe, it is pretty loud.
Have not taken it above 40 MPH yet so we shall see how it affects side winds on the highway, and if it helps remove heat without the A/C .
Overall, it is a well built device, doesn't rattle or move, holds the window in location good. Only down side I could see is that it is made of steel and could scratch the car if it is dropped on a body panel (which my grandson did right away.)
available on Amazon
available on Amazon
