1 - 13 of 13 Posts
Vendor
We are proud to introduce a new line of performance exhaust by Solo Performance. Solo Performance has been building exhaust systems since 1960's and had designed a custom exhaust system for the smart car.
It is well made, light and most importantly gives you a gain in performance without all that noise. In addition, we are introducing it at a reduced price for the month of April.
Here is the direct link:
Smart Madness - Smart Car Parts and Accessories
Thank you!
WOW
very nice. that is what i have been looking for. have been wanting a single oval tip that was quiet. looks and sounds very nice and the price is great.
Vendor
How does that flex joint work? What type of steel/grade? How many joints between muffler and exhaust tip?
Frank
Thank you for your interest....
1) Flex- The spherical joint has shouldered spring bolts. This allows the installer to tighten them to a pre-engineered spec and no more. This torque, once the spring bolts bottom out, allows the spherical joint to seal on the gasket. The joint is not allowed to be tightened to the point of immobility. It’s an engineered spec that allows for movement and seal.
2) The pipe steel that is used is T409 stainless. The pipe is all mandrel bent. The muffler and tip are T304 stainless.
3) The front elbow has the flex joint in it and can be removed for easy installation. The rest of the unit is one piece. There is a one piece pipe on the inlet side of the muffler and a one piece pipe that goes from the muffler outlet to the tip. There are no weld joints that connect 2 pieces of pipe. All of the pipes are one piece. The only welding (stainless weld) is from muffler to pipe and from pipe to tip.
We have a limited supply of these exhausts and more are in production now. Once our first batch sells out (expected by the end of today maybe tomorrow based on emails and in store customer interest) we will continue to sell them as a pre sale at the introductory price. All pre orders should be filled within 2-3 weeks.
Thank you everyone....
Boris
Dyno numbers pre and post installation? Everyone keeps claiming performance gains but would sure be nice to actually see objective proof ( not SOTP)....
Vendor
I agree with your point. One challenge we have is too few exhausts at this time, the lack of a stock car and an owner who is willing to do a test and time.
When we have enough exhausts in to fill the current demand and a bit more time along with a willing owner we will get the dyno done and post the results. Meanwhile I can tell you that the exhaust looks great, weight less, has a beautiful sound, built well and those that have put one on loved it.
Thanks!
Vendor
Discussion Starter #9
The first two batches sold out pretty quick to our walk in customers.
In our shop we have a display that shows all the exhausts that are available for the smart. When people have an opportunity to pick up each exhaust, examine the details in the workmanship, the weight, the finish and the overall look most have been going to the Remus and the Solo. If money is not an issue and you are not planning to use a body kit then the Remus is the hands down winner. If you are looking for the best bang for the buck quality exhaust or plan to maybe use a body kit sometime later then it has been the Solo.
Since our first two orders sold out quickly we have placed a larger order and it is scheduled to be delivered April 15th. All orders placed prior to today have been filled and anything from today on will be filled on the 16th. So, if you are thinking about getting an exhaust this is a great option.
Thank you.
Vendor
Discussion Starter #11
Our new shipment of Solo exhausts has just come in.
We have had several folks ask us for db ratings and we do not have them.
Soooooo, here is the deal:
We need someone to purchase the new exhaust and measure the db's. Once you have that and notify us of what it is we will issue you a store credit of $50 towards future purchases.
Please note...We only need one volunteer. It would be great if you have a DTH or a Breathless exhaust now and will be upgrading to the Solo. Then we can really get a great comparison. We have them all of the exhausts in stock and can easily show folks the difference in our store, but that does not help with online sales.
Anyone? :)
whats the weight of ur system versus the stock system?? ie how much does the stock muffler and pipe weigh, and then what does ur system weigh? thanks.
Vendor
Discussion Starter #13
I do not recall the exact weight difference, but from what I remember it was about half the weight of the stock unit.
We'll put both on the scale and I will post the info here.
1 - 13 of 13 Posts
