Hi all,
I recently bought a 2014 Smart fortwo ED with a "Drive Sys, Engine Off" message in the guage cluster. The HV battery was at 30% on the SOC guage when I purchased it and it had crept down to 18.8% (according to the arduino battery health tool I assembled) It won't start, drive or charge. After reading as much as I could find about similar issues, I checked for wire chafing and sure enough, there were 3 chaffed wires(2 of these I believe to be CANbus wires since they were a twisted pair). I repaired them and bought an Autel ap200H and cleared all codes. There are 4 stored codes that the ap200h is unable to clear. (The 12v battery was low when I purchased the vehicle, and I have since replaced it with a new battery)
P007108
The outside temperature sensor is faulty. A signal/message
fault exists
C212B16
The vacuum pump for supplying the brake system is faulty.
The limit value of the electrical voltage is not reached
U010387
Communication with the Electronic Selector Module (ESM/
EWM) is faulty. The message is missing
P056200
The on-board power supply voltage is too low.
I'm assuming these codes are responsible for the no start/no charge issue.
I'm hoping someone can help me clear these codes with a generic elm327 bluetooth dongle or the autel ap200h.
Or steer me in the correct direction to what the cause of the no start/ no charge would be.
Thank you all for sharing your knowledge and experience.
-Brian
P007108
fault exists
C212B16
U010387
P056200
-Brian
