Hello group!
I have been driving electric for just over 5 years, but have had hybrids since our 2002 Prius. I leased a 2012 Leaf for 3 years, then got a deal on a two-year lease on an i3-REX. I have been waiting for a long-range EV, but the 220-mile Leaf and Tesla M3 will not be available until the end of the year. Since I could not extend my i3 lease, and missed out on a 8-month lease swap, I still wanted to be driving electric for my 36-mile each-way commute in Michigan.
So, I found a 2013 smart fortwo Electric Drive with cruise (rare option!), heated seats, NAV, DRL and Ambient Lighting for pretty cheap, except it was in Arizona. It was not a fun process buying a car sight-unseen, but it arrived last week, right in the middle of our February cold snap (7°F). But, I have a few winters experience with EV's - had my blanket handy
I had working wipers/heated seats the first day, but the windshield washer did not function. But the next day, no wipers nor heated seats! Fuse chart was a bit misleading - the wiper fuse was fine, but finally found a blown 10A fuse that mentions a lot of functions, included wiper switch, and the washer pump. That fixed the wiper/seat issue. Checking under the "lid" for the first time, I saw that the washer fluid was a solid block of ice! I guess they do not need low-temp fluid in AZ! ;-)
BUT - still have a couple of issues:
1. 12V Power Outlet does not work with key ON or OFF. Checked fuse, removed the panel with the socket to check wiring - seems ok. Any ideas where to check next? It would be nice to have wiring diagrams.
2. I have the "pre-heat the car before leaving in the morning" part figured out, but the manual seems to imply you can also set it to charge when electric rates are cheaper. I have time-of-day electric service, with a 4¢/kWh rate from 11pm-7am. The Leaf and i3 had a fairly easy way to set this up.
- I guess my question is: Can I come home and plug in the car at 6pm, but not have it start charging until 11pm or later, AND still have the car pre-heat in the morning while still plugged in?
Thanks in advance! I have already found a lot of good tips on the site.
Matt
Matt
