1 - 20 of 22 Posts
Good find! Just guessing but I doubt the battery will be up front in the fortwo as Renault has no input on that car and Mercedes likes the battery inside the car (for some reason.) Also, it sounded like at least the "hood" is a plastic piece. :)
I betcha the smart fortwo (453) will have the battery in exactly the same place and with the same "hood" arrangement! Such are the ways of platform-sharing. We already know the 453 has more of a "hood" than the 451 has, and that facilitates putting the battery there instead of under the floorboards.
Firewall, battery, coolant bottle, brake master cylinder, washer bottle, pedal cluster, etc are likely to be common parts across all models on this vehicle platform, doesn't matter two-seat or four-seat.
Let's scratch the crap out of the car. If you ever had to jump start a smart. It makes sense the battery is under the hood.
Tridion Cell is another story...
I still firmly believe a Tridion Cell is there...but it will definitely look thin on the forfour!
Check out the bulge under the door sills; now imagine that with a Tridion Cell and no camo. It's definitely different from the fourjoy Concept (which has a Tridion Cell thicker than the current fortwo's). Interesting.
OK, I'll bet you coffee and donuts at Tim Hortons the battery stays inside the car. :D
You're on :)
More speculative vehicle-platform meanderings follow. Keep in mind that I do work for a large company that builds automation equipment for welding together automotive body shells ... the same company that builds that Tridion shell (but the engineering for the 453 was done across the pond, not at the division that I deal with).
There is another rationale for getting the battery out of the passenger footwell: Right hand drive. The original smart (450) was not designed with right hand drive in mind. They ended up having to build an entire mirror-image front section of the floor pan in order to do it because the battery had to be on the other side. $$$. The 451 has the same issue.
Obviously there are some differences because of the pedal cluster. But the smart (LOL) engineering companies use the same floor pan with a pedal module that bolts in, and the other side gets a blanking plate. Or the firewall where the pedal cluster attaches is a separate part from the floor pan and only that part has to be different left to right (prior to being welded into the structure), not the main floor pan itself. But the bottom line is that they want to make as many different models as much the same underneath as they can. RHD, LHD, Twingo, forfour, fortwo, doesn't matter ... Make 'em all the same (except for the length)!
Jack up a plain jane Mk6 VW Golf on a hoist, and jack up a same-generation fancy Audi TT on the adjacent hoist. If the TT is a base model (front drive), you will not be able to tell the difference between them looking from underneath. If the TT is the normal all-wheel-drive version, you'll be able to tell because of the propeller shaft and the rear diff. BUT ... you can unbolt the fuel tank and rear suspension module and transmission and related bits and pieces from both cars, and swap them! It all bolts in, the floor pan is the same!
Very true, but I think when Renault dropped out of the two seater version of this car it became a Daimler design pretty much all the way. When we look at the spy shots of the 453 fortwo, even with the (somewhat) flatter nose there's not much more distance from the leading edge of the front wheel arch to the front edge of the car than with the 451 fortwo. This is all speculation and sharing a lot of the design under the skin would certainly help keep costs down, but the new fortwo appears to have kept a lot of its smart DNA. :)
PS - I prefer the dark roast coffee and the chocolate dipped donuts...
Good point Jwight! Renault dropped out of two seater development for the project...as far as I'm concerned, the fortwo will only be mechanically similar to the Twingo.
Again though, the forfour might be a different story entirely. :eek:
This.
These pics of the pre-production models with body wrap spell it out very clearly. If the car is divided in three sections -- the Fortwo commonality with the Twingo would be confined to the fore and aft sections. The Forfour will largely mirror the Twingo configuration. The entire purpose of sharing the development with Renault is to SHARE, so the Fortwo battery will definitely be up front. I'm curious as to how much of the interior bits will cross over.
This other set of winter test shots with the Twingo makes me wonder if Smart will de-emphasize the Tridion. The 2014's have more possibilities for matching the plastic panels to the Tridion... and these last pics highlight a monochromatic 2014 model.
Ditto! The fortwo will clearly have a Tridion Cell (look at the winter test shots and follow the door line, it's the same as the 451) but the forfour? Looks like it could go either way. The door line shape doesn't really scream "Tridion Cell" to me, but instead just a more traditional body.
I want to say the fortwo will also have a hood latch key lock on the driver's side. But i think our pull handles will be inboard of the key slot.
I'm gonna guess the opposite side pull handle will do nothing till the lock side handle is pulled first
They added a key lock so you wouldn't be able to steal the battery.
The fortwo is the most stolen car in France. With previous generations, you can steal some expensive equipment and even access the cabin's electrics simply by going through the service flap. You don't even need to unlock the doors and you can make off with panels, wheels, and most of the front end.
I imagine the lock is more designed with the car's home market in mind. :)
They did offer wheel locks for the 451 on the European market.
Though, standard wheel locks are really only going to stop/slow bad car thieves...If someone is good enough and they have the tools, standard wheel locks can be defeated...
1 - 20 of 22 Posts
