Recalls
PROVIDED BY
ELECTRICAL SYSTEM:BATTERY
Feb 24 2020
If the high-voltage battery fails, the vehicle may stall, increasing the risk of a crash. In addition, an electrical arc inside the battery increases the risk of a fire.
Summary:
Mercedes-Benz USA, LLC. (MBUSA) is recalling one 2019 Smart Fortwo Electric Drive vehicle. A welded joint within the high-voltage battery main cell conductors may detach and interrupt electrical contact, resulting in sudden battery failure. The detached weld may also cause an electrical arc which can ignite inside the battery cells.
What should you do:
MBUSA will notify the owner, and a dealer will replace the high-voltage battery, free of charge. The owner was notified of the safety risk on March 31, 2020. A second letter will be sent once the remedy is available. Owners may contact MBUSA customer service at 1-800-367-6372.
For more information:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
NHTSA CAMPAIGN ID Number: 20V107000
Potential Number of Units Affected: 1
www.consumerreports.org
PROVIDED BY
Feb 24 2020
Summary:
What should you do:
2019 Smart ForTwo Reliability - Consumer Reports
Get reliability information for the 2019 Smart ForTwo from Consumer Reports, which combines extensive survey data and expert technical knowledge.
