No power going to #14 ac Fuse
1134 Views 9 Replies 1 Participant Last post by  Gmk5150
2012 smart i got no power on fuse 14 in sam box AC light on dash lites up
looking for a suggestion
1 - 10 of 10 Posts
Ok, first of all, the "AC" light that you see in the dash is the Check Engine Light (CEL). You need to hook the car up to an OBD2 scanner to read the code and google it. The OBD2 slot is under the dash where your right leg would be if you're in the driver's seat. Let us know what the codes are. Fuse 14 if blown might just be inconsequential. Replace it, anyway. Do you see a "P" on the dash as you try to start your smart? What do you mean by "no power"? Horn, light, radio work? Let us know.
No its Ac lite on dash that turns on off...For AC..but no power on fuse 14 in sam Box
SO your car can start and everything? You just don't have AC? AC not cold, is that all you are complaining about? Also, I don't know of any AC light on the dash unless you mean the middle console just above the radio.
There is no codes Ac not work car runs fine...but no power on fuse 14 fuse is Fine That u for Help im new here:)
Yes button that turns ac on Works but ac dont tested no voltage a 14 fuse
OK thanks for clarifying! You title "No Power" plus "light on dash" were really confusing.
Assuming the fuse is good, since you have the AC switch light on/off, you might want to trace the wiring all the way upto the compressor on the side of the engine and see if they are intact. My 08 Cheewawa had her engine changed and then the AC didn't work until one of my friends discovered the AC cable on the compressor's end not connected after the engine swap. Once reconnected, all was good.
Thankk u kindly i will check...im confused who No power in fuse block...not sure if bad relay possible
Me again i got 2012 smart car...ac not working #14 fuse in Sam box completely dead...any ideas guys 🔥 ac button on dash works...is there a ac relay ..Fuse is dead Fuse is fine Thank if u can assist...
Got the answer..sam will not supply voltage to 14 fuse Less freon is at correct pressure 🥶
Reactions: 2
1 - 10 of 10 Posts
