I just had my red 08 cabrio in for its 20K servicing last week, but last night I had an unpleasant situation happen with the transmission.
I was on my way to meet some folks and running just about on time, but I stopped to get a Diet Coke at a convenience store and set up my GPS for the last leg of the journey into unknown (for me) territory. When I started up and put the gearshift into reverse, the indicator on the control panel just went from P to blank and the car didn't move. I could shift into neutral and drive just fine, but even after a couple of shutdowns and restarts, and some tentative jiggling of the shift lever to see if there was a loose connection of some sort, nothing happened.
Fortunately, I had enough room in front of me that when I shifted into drive and moved forward a few inches, the next time I shifted into reverse the wonderful R reappeared.
This morning, when I called smart center portland and talked to Bryce, their service manager, he didn't shilly-shally for a minute about bringing the car in and getting the clutch replaced, a problem I hadn't seen on the board here myself until today. Fortunately, I'm a couple months shy of two years and had just over 21K on the car, so it's still on warranty.
Just wanted to let anyone who happens to run across the same issue of a potential workaround (although it won't do you much good if you're in a tight parallel parking spot or up against a curb and can't safely move forward a few inches) and make sure smart center portland gets the recognition it deserves for great customer service (at least to me).
