Got cold out finally, 15 degrees and on the way home my smart started acting up again. 146,xxx miles and I got a P0303 code, then after resetting, I got a P0302 but it went away when I restarted the engine.
I hope it is the plugs I installed as they were the standard Denso plugs and not the long life ones. It could be time for new ones as it has been right around 30K miles, and I do have these fancy RED coils from Smart Madness (with lifetime warranty)
It is possible I got some bad gas, used the same station I always use, but I did fill up before driving to work... At least I made it home (46 miles )
