Twice I attempted to start the car - it did not fire. In fact it would have continued cranking had I not moved the key back to the off position. On re-try the car started right up.
I think that in each case I was in a hurry and I may have moved from the key from the Off position to Start position rather quickly. Normally I habitually pause at the ON position for a moment before moving to Start (I drove diesels for a while).
Im guessing that an ignition relay of some sort needs to activate before the starter cranks and its just a bit slow.
Anyone else had this problem?
