Had access to another Snap-on ETHOS-PRO OBD Code reader, which has most modern car software installed. Code still the same, ringing out both the connections on the NEW driver seat belt force limiter, with perfect .0001 readings, so I focused on the wiring, and saw normal readings for ringing out a circuit of the type. Focused on the connectors, as there is ALLOT of info leading back to them, troubleshooting these systems SRS codes. Also focused on the lay of the wiring, which are routed very poorly, and terrible bends/kinks considering the importance of the system the are in. Corrected the lay and routing, and cleaned the connectors. Ran the system through another scan and no SRS light. Not sure which was the actual problem, but I suspect a wire was not happy.
However the problem is now corrected without a trip to the dealer, which is a good thing.
