Thanks been working on it all summerLooks good. Miss Mercedes should like it, too.
28inch 10 wide on stock rims 20 psi makes them about 30 inches tallWhat tires and what sizes?
if I drop tire air pressure to about 15psi it like riding on marshmallows ridesI bet that ride is a lot smoother on the road. Except for the tire noise.... Well done.
all parts are made in my shop front has a lift blocks 3.5 inches between the frame and rack and i pushed the rack forward to get clearance from the body frame rear has spring and shock blocksOk, so give us the details. Do you have a lift kit or is it just a tire swap? Where is the light bar and front crash bar from? The rock sliders look like they are from an ATV or are they custom made?
I can do 60 mph on the high way and it run well in the sand have calmed a few hills gets a little doged at the topWhat's your top speed? The biggest thing keeping me going whole hog with an offroad build is that I still need it to cross the country under its own power. My 2012 only has a two inch tire lift. Still got down then up a waterfall! View attachment 62153
