Oil Change Question
3877 Views 13 Replies 6 Participants Last post by  Old smart
I changed the oil in my smarty this weekend but I mesread the owner's manual and didn't buy enough oil the first time out (bonehead move #1). I ran into the auto store this morning and, because I was in a rush, bought the same brand but wrong weight oil. (bonehead move #2)
Right now the car has 2 qts of Mobile 1 synthetic 0W - 40 and I bought 2 more qts of Mobile 1 synthetic 0W-30.
2 questions - (1) can I drive the car a short distance with only 2 qts in it?
If not (2) can I mix the oil (maybe end up with 0W-35?)
1 - 14 of 14 Posts
Don't drive your car with 2 quarts in it. It will be OK to run the 0-W30 with the 0-W40. The oils will mix fine and the 30 weight is good to about 90 degees farenheit.
Yeah, you'll just end up with a "thinner" 40 weight. Pretty well harmless.
As the lead in says, more than you ever wanted to know: Vintage Triumph Register - VTR :)
Be cautious of the American Petroleum Institute SG grade oils refered to in the VTR ("All of the oils above meet current SG/CD ratings and all vehicle manufacture's warranty requirements in the proper viscosity. All are "good enough", but those with the better numbers are icing on the cake."). SG oils became obsolete years ago; the current API grade for engines designed and built since 2004 is "SM."
OIL CHANGE,at 1030,miles.
Just did it this morning.Got the info from Old Smart on filter.Gave NAPA the Misti. number and they had the one. Slightly bigger but not a problem.
Never figured out if they ship the car with reg. oil or mobil 1.But it didn't look synthetic.Anyways,used Penz. 5w30,probly 5/40 or 10 /40 next time.
Oil wrench too big,pipe wrench worked fine.Won't need that next time.Drain plug,didn't have large enough socket.Hammer and cresent wrench worked.Won't need that either agin.I know a cresent wrench near a car is a bad thing,it won't happen next time.
... Never figured out if they ship the car with reg. oil or mobil 1.But it didn't look synthetic. ...
smartUSA has let it slip that the engines come out of Japan with a non-synthetic engine oil, and is the reason that sUSA has been recently experimenting with an early change to synthetic oil at the U.S. vehicle processing centers (all getting Mobil 1 0W-40). sUSA doesn't want to wait until the first scheduled maintenance at 1yr/10K miles to change to synthetic.
When I asked the reason for the early change (wanting to get synthetic in for the sake of the engine, or wanting an early engine flush, or wanting to get Mobil 1 in to satisfy some contractual agreement) they stopped communicating. The experiment was/is to compare doing the change at the VPCs or in Japan before shipment of the engines to Hambach. Changing the oil at Hambach seems not to have been in consideration.
Also, no response was returned when asked if the Japanese fossil oil was intended to be a break-in oil for some period.
by the way
That little filter in the drain plug?never saw that befor,what's it there for?If it is 'clean' than does it mean I didn't need to change the oil so soon? Still think if they ship the car with reg. oil and recommend 10,000 mile oil changes it may be a scam.Our 07, f150 has a BP sticker,Ethanol,but have never found a BP station that had ethanol.
OLD OIL?
So if we want to conserve oil,a country that has no oil,ships its cars with old,'basic' oil,so you can get rid of it and conserve oil?
Sort of off topic, but the assumption that "we" want to conserve oil may be faulty. As the manufacturers improve engine technology and the oil companies improve their oils to enable longer oil change intervals, old habits die hard - some folks can't let go of the 3K mile oil change, others want to do the "engine flush" thing, etc. Must really confuse the auto and oil company engineers. :)
Jwight
Worked in a power station 25 years,never saw an engineer that needed any help in being confused. The point was,if you are going to get paid to 'engineer 'a car and expect the user to use Synthitic oil,why would you ship it with,'old' oil? Yes,it has to do with conservation.If every car produced hat pure synthetic,and recommended 10,000 miles changes,sell your stock in jiffy lube.
... why would you ship it with,'old' oil? ...
Modern API SM grade fossil oil isn't exactly "'old' oil." It is perfecty acceptable if used within its intended parameters - that its extreme ends of its viscosity range aren't challenged, and that it not used in extended oil change intervals (10K +). Many manufacturers still specify a 7,500 mile interval (in ideal, non-severe service use), and a fossil SM can do that.
We don't know what Mitsu's intended interval is; M-B won't pass on that info.
Synthetic
Get your point,I usely do the 5000 mile thing,sometimes less ,sometimes more.Fact is,anyone that has a high milg. car,did it .We used synthetic oil on B 52"s back in 67/68,so it has been around a long time.Allways wondered what would happen if I put that stuff in my Ford 260 v/8,but I don't think it was multi grade .Not the same as a j57 engine.
Other than the Germans' WWII exigencies, synthetic lubricants were first used here as aviation turbine oils, partucularly because of the extreme viscosity properties. That "Buff-Hotels" are still a mainstay confirms that synthetics in their case have done their jobs.
1 - 14 of 14 Posts
