41 - 49 of 49 Posts
Kind of defeats the whole 'oil change from the top' thing when he raised it up to change the filter... I know it was so it is easier to see the filter mounting but still...
Being the proud owner of a smart with a stripped oil pan drain, I am looking for easier methods to repair it , sounds like a new oil pan is the least expensive way to go. My only concern is that I will still be looking at aluminum threads with a steel drain plug, which is what I started with and it could happen again. Been thinking about one of those drain plug valves..
++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair,
Jabsco 17800-2000 Marine Porta Quick Oil Changer, 3.5 gallon, 12 volt.
Simple, quick and clean. Available at Amazon, $201.64. Not cheap, but if you do not have a lift it makes a potentially horrible mess into an easy job. This pump, a K&N HP-1008 filter (the one with the 1" nut on the bottom), and you are finished in a few clean minutes.
Jim
What causes the OEM design to make oil and filter changing to be so difficult that it requires a mod for do-it-yourselfers?
It's a gift to the dealers' service departments from the OEM. It's even more profitable if you require a special tool only the manufacturer makes because he has a patent on the tool and can charge anything he likes for it. They all do this, not just Smart/MB....
MB/Smart's $10,000 laptop with the yearly $450 "subscription" to test its computers and look at its instruction manual is an even bigger ripoff.
Jim
Oil Suction Gun - Save on this Suction Gun at Harbor Freight
Works great..Steel cylinder...$12. Great for motorcycles and generators, too!
:eek:
Once you get the time-sert or helicoil put in, go ahead and install the Fumoto Valve, and oil changing becomes a snap of a lever. There is a spring catch, so it doesn't accidentally open. A strap wrench makes removing the oil filter a piece of cake also. Both are easily accessible, just be careful around the muffler when removing the filter so you don't burn your arm. Don't ask me how I know. :p
The kit from Uptown Dog co. has the necessary spacer for the smart, so get yours from there. I highly recommend it. It is one of my favorite mods.
Take my smart to our local GM dealer (small town USA) I bring oil and filter, he charges $20 vacuumed inside cleaned windows (inside and out)
I'm not going to change my own oil to save $20.
I am. With the Fumoto valve it's a 15 minute job. I don't make 80 bucks an hour, so it's a good deal for me.
I looked at these, at $487 for the kit, a $80 oil pan is much more reasonable. If I had a few smart pans to do it would be worthwhile
TIME-SERT Drain Pan Kit M24 x 1.5 Part # 2415C : Amazon.com : Automotive
I assumed taking the car to a place that claimed to specialize in oil changes was a good idea, more convenient, etc. but there I sat on a Saturday afternoon with a stripped out oil pan... Luckily I remembered something about a Dodge truck plug being longer and the local parts place had one on hand.. Thanks SCOA!!
41 - 49 of 49 Posts
