Not a drop ever. (Except last year my garage where I lived at the time, cracked the oil pan. I spotted the leak immediately and got them to replace it with a new one.)
Not a drop ever. (Except last year my garage where I lived at the time, cracked the oil pan. I spotted the leak immediately and got them to replace it with a new one.)So you were not losing oil prior to hitting the bambino?
When not driving, we cannot test the "spray at high oil pressure" because there is no load and the RPMs max at 3500. The oil filter was involved in the accident. While it was not visibly damaged, we will replace for want of any other options.Update. ...
Correct. Not a drop. Dipstick at full for 70,000 miles (thanks Mobile 1)So you were not losing oil prior to hitting the bambino?
Not loose but covered with blood and fur from the accident so I'm thinking a tiny punctureEmm, I'd check and see if the oil filter is loose. Maybe you might wanna change the oil filter. Now I know that you mentioned that there was no sign of any leaks around the engine. SO, yeah, it's a longshot.
I like it! Using a mirror and flashlight to view, we saw that both sides of the belly pan is also dry, no oil. This really has the mechanic's goat ... he asked all of the questions here and more.Just a whacky thought, but if you know someone with an action camera (like a GoPro), you could secure it under the car while you are driving and see if you can spot where the leak is coming from. It might be worth taking the belly pan off and moving the camera between runs to try and spot the leak.
The oil isn’t leaking into the coolant, right? This would indicate a blown head gasket.
