"wrench" do you have enough clearance under to apply force? Ill try the wrench
It's a 24mm socket ....6 Point Socket, or you'll wreck it...
http://www.smartcarofamerica.com/forums/f25/09-451-oil-pan-replacement-61818/index2.html
That is not what comes up when you enter car information.What is the correct size valve for 2013 Smart? Never mind I click the link 22mm 1.5
FG7BN nipple drain valve or
FG7B standard drain valve
There were NO 2007 451's !!!That is not what comes up when you enter car information.
Selected vehicle Smart fortwo (451) 1.0 (999 M132 petrol) 2007-
F-106N standard drain valve
14mm outside diameter, 1.5mm pitch
is this wrong information from the site?
Actually, there were 2007 451's. Remember, it was introduced in Europe a year before we got it.There were NO 2007 451's !!!
2007 is a 450
The FG7B (N) are the correct numbers![]()
Yea...my badActually, there were 2007 451's. Remember, it was introduced in Europe a year before we got it.![]()
But you are partially correct, there were no 2007 451 in the USA. Not trying to bust your chops buddy...0
I've always used a standard 1/2" drive ratchet and 24mm socket to remove mine. The extension for my floor jack fits right over my ratchet handle to give me the leverage to break it loose. I just snug it with the ratchet(no extension) when I put it back in, but the heat cycles really tighten it down.
Same here....For some unknown reason the oil drain bolts on all three of our smarts have always worked as designed....![]()
