1 - 9 of 9 Posts
to what advantage is the screen on the drain plug, only catching large chunks of metal....and if you have that your motor is toast. I was thinking of taking it off and epoxy a magnet to the bolt or find one that would fit in the screen.
I guess Mitsubishi would be the ones to ask. What other applications besides the Mirage was this engine used for? Perhaps it's just a carryover.
OR
Maybe it's there to give old farts something to wonder and contemplate about.
I resemble that remark! Yesterday, I noticed the same thing, the screen is quite course, probably would not catch small tiny bits of metal.
That prompted me to examine the drained oil closely. I ran a magnet through the old oil, the old filter, and the inlet of the drain plug... nothing found!
I wouldn't think they would put it there if it didn't serve a purpose. Big corporations cut pennies to save money. Yes it might be less than a dollar to make that part but you have to multiply that by how many of these engines Mitsubishi made. I would guess with the multiple applications it's no small number.
The screen on the end of the oil drain plug is there because this is also the oil-pickup. If too fine it risks being plugged by an accumulation of sludge... on those engines where one never does an oil change. I'd guess the sizing is to protect the oil pump from ingesting anything big enough to damage it. The oil filter then removes the fine stuff.
Don't remove the screen, just clean it if necessary when performing an oil change.
~toaster
1 - 9 of 9 Posts
