Either from your smart center or a local parts store:
Mobil 1 M1-108 (Champion Labs)
Purolator PureOne Premium Plus PL14612 (full fleece)
K&N KN147 (Champion Labs)
Bosch Filtec 3300
AMSoil EAOM103 (full fleece)
Wix 51365
Napa 1365
Carquest 83365
STP S6607
Fram PH6607
Fram Tough Guard TG6607
Motorcraft FL-810
Beck-Arnley 041-8055
Mitsubishi MD134953
Yamaha 5DM-13440-00
smart A 1230A040
Local stores will not carry the smart filter :)
Oil filters
The Purolator PureOne Premium Plus PL14612 (full fleece)
is nearly identical to the filtering and by-pass pressure recommended by Mercedes for extended drain applications.
By-pass pressure is important because any oil that by-passes doesn't go through the filter. Full fleece is important if you want to keep the micro contaminants in the filter and not circulating through your engine.
If you're going to change your oil more often than specified, then I wouldn't worry about it, but if you're going to use the same oil for 10,000 miles, I'd use the Purolator PL14612
