1 - 4 of 4 Posts
Beyond purchase, what (if anything) is out of the ordinary in the cost of ongoing ownership? Aside from the relatively short warranty term, that is.
For example, can a typical owner change the oil periodically himself, or must it be done by a qualified mechanic...or, worse, at Mercedes-level labor rates at a dealership?
Thanks...
Doing my own except the 60K valve check. Oil and filter are very easy. It would be much easier if we could get a full service manual.
Ful Service Manual?
"...if we could get a full service manual."
Thanks, Duckhunter.
Any possibility that manual will become available to us...?
The Smart's relatively new in the USA, and has a fairly new engine and transmission design. I'd opt for an extended warranty to dampen any fears.
Oil changes are reputed to be simple for anyone that's done one before - biggest challenge is finding the right filter and getting the old one off - the filter and/or drain plug are on pretty tight, I read.
Oil change interval is listed at 10k with Mobil 1 synthetic (weight depends on your geography). Some change earlier, some wait until 10k... heavy debate on that subject, so just choose your own path. Regardless, $200 or so for MB rates include oil change and 10k annual checkup - compare to 3k intervals with dino oil (30 bucks x 4 plus time spent) and if you don't change it yourself, the 10k interval evens things out.
1 - 4 of 4 Posts
