a: coolant loop
b: refrigeration loop
N83: Charger
M5: Motor
N129/1: Inverter
G5: Battery
R101: Battery heater
A9/6: refrigeration compressor
Sadly, this diagram is missing the heat exchanger between the two loops. It sits in the battery coolant loop with the M43 pumps.
@Blaine: Where did you get those numbers for the activation threshold temperatures from? I've long been trying to find that information! The lower one is hard to observe, unless you want to spend the night outside in the dead of winter. I'm sure the upper one is wrong - I have never been able to observe the compressor turning on to cool the battery, and it frequently gets a bit above 30C in the summer.
I honestly don't remember where the 30C number came from and I haven't spent the effort to confirm the exact trigger threshold. I do know that from looking at the HV temperature sensors after a modest highway run the cooler doesn't come on below 30C. Numbers in the 20's, no AC and no physical indication of fan etc. Similarly, after extended highway runs I'm fairly sure that the cooler does come on because I've pulled the car into the garage and heard the non-cabin fan running while everything else was off, but the car was still 'on'. The noise profile is quite different.
For everyone else: those temperatures are *internal* battery temps. There is a temperature sensor per stack in the battery pack.
Its hard to imagine that MB would have put all that extra coolant plumbing into the battery if they weren't going to use it to cool the system. I suppose you might get some convection effect, but that also seems unreasonable. Plus the coolant pump is fairly large.
I'm sure my coolant pump is working because it leaked and I had to get the gaskets replaced. The service tech cleaned and ran checks on it so I *assume* that they made sure it was moving coolant. The AC is definitely working.
The -10C is from a partial tech sheet that someone posted. According to the notes it's only applicable while the car is on external power. Interestingly, that diagram is slightly different from the one you posted and it does show more interconnects.
There is some anecdotal evidence that in really cold conditions (-32C ?) that something warms the battery or fools the BMS. There have been a few posts where people said the car was "dead" when they tried to start it but if they waited with the key 'on' then it would eventually start up. Maybe that was just their bodies warming the cabin up, but :shrug:
You can find the 451ED related manuals pubs that I've collected in a
google docs folder. including the other diagram. I'd love to gather more stuff if anyone wants to share.
We're getting into the warm weather here so I'll be able to hook up the battery tool and do a bit more monitoring. If work slows down maybe I'll get the time to build out more extensive logging features.
